Finishing Services
Alodine
Chromate Conversion Coating
Clear, Gold
Applications
Tools, hardware, electrical systems
Thickness
0.25-1.0 µm0.00001-0.00004 inches
Chromate conversion coating, more commonly known as chem film or by its brand name Alodine, is a chemical coating that passivates and protects aluminum from corrosion. It is also used as a base layer before priming and painting parts. The standard most commonly specified in engineering applications is MIL-DTL-5541F, which refers specifically to coating of aluminum alloys.
This protective layer is much thinner than an anodizing layer, and while both are created by immersion of parts into a bath, Alodine is a simple chemical coating and the process does not use electrical current.
Alodine is a slightly cheaper process than anodizing, though it is more prone to scratches, wear, and cosmetic damage. The most common color of the coating is an iridescent greenish-gold, and thus it may also be used for cosmetic purposes. However, this color comes from hexavalent chromium, which is toxic, so for RoHS compliance needs, there are clear versions of the coating available as well.
Design considerations
  • Alodine coatings offer a much greater electrical conductivity than bare aluminum
  • Media Blast parts before Alodine to create a more consistent coating that hides small machine marks
The Future of CNC Machining – 2024 and Beyond
In the dynamic world of manufacturing, CNC machining stands at the forefront of innovation. This field is not just about shaping materials; it’s about shaping the future. As we delve into 2024 and beyond, the landscape of CNC machining is evolving rapidly, driven by technological advancements and industry demands.  Throughout this article, we’re using AI […]
CNC Machining Design Stack: From Design to Prototype
Your comprehensive toolkit for mastering the art of designing parts for CNC machining and seamlessly progressing from concept to prototype. Here’s what’s included:
