Finishing Services
Powder Coating
Black (20% or 90% gloss)White (20% or 90% gloss)
Gloss or semi-gloss
Can be applied with
Media blasting, tumbling (neither is needed)
Color Options
Powder Coating
Powder Coating
Powder coating is a process in which a dry powder paint (either a thermoplastic or thermoset polymer) is applied to a metal surface using electrostatic application. Unlike traditional liquid paint, powder coating does not need a solvent to keep the binder and filler of the paint in liquid suspension. This allows for application of thicker coatings without running or sagging, and the coatings are also tougher as a result.
The powder coating process starts off by electrically grounding the part to be painted, which gives it a net negative charge. After grounding, the paint is sprayed at the part using a corona gun, which applies a positive charge to the powder. The polarization of the two components causes the powder to stick to the metal, where it will remain so long as it is undisturbed.
After the powder has reached a specified thickness on the part, it is cured into a polymeric film using elevated temperatures (~200°C), such as with a convection oven. Thermosetting polymers will crosslink during the curing process to improve performance, but thermoplastic varieties simply flow while heated to form the final coating.
Design considerations
  • This process adds substantial thickness to a part’s surface, so plugging and masking threaded/reamed holes or other critical-to-function surfaces is recommended.
  • Powder coating polymers are usually insulative and offer poor electrical conductivity.
CNC Machining Design Stack: From Design to Prototype
Your comprehensive toolkit for mastering the art of designing parts for CNC machining and seamlessly progressing from concept to prototype. Here’s what’s included:
Finding the Right Secondary Operations after CNC machining, Part I: Heat Treatments
Welcome to the world of post-CNC heat treatment! Now that you’ve successfully CNC machined your parts, it’s time to give them the TLC they deserve. Don’t let those raw components go out into the world without a little extra oomph.  Once you’ve finished CNC machining your parts, your work isn’t done. Those raw components might […]
