Rylo 360° Camera
Injection molding
Low minimum order quantities and free manufacturability feedback with every quote.
Download PDF Icon
Download our free design guide
Parts Time
Parts as Fast as 10 days
From Prototype to Production
Man working with design mold
Rapid Design Molds
Ideal for part design validation, low volume production, and bridge production quantities.
No minimum order quantities
Complex design accepted
Materials, finishes & post-processing
Production Tooling
Ideal for higher volume production parts, starting at 10,000 units. Tooling costs are higher than Rapid Design Molds, but tooling construction allows for lower part pricing.
10k-500k units
Steel tooling
Multi-cavity tooling
Picture of production parts
Quality Parts
Vetted local & overseas suppliers
Parts built to spec, guaranteed
ISO certification & inspection
Private & Secure
Secure file transfers & storage
Anonymized identity w/ suppliers
Industry Expertise
U.S. & China-based service teams
Available via chat, phone, & email
Over 10 million parts manufactured
Get Free Expert
Manufacturability Feedback
1
Upon upload to the Fictiv platform instant quoter, you’ll receive instant feedback on major cost drivers for injection molding.
2
Upon full quote submission, you’ll receive a more in-depth manufacturability analysis.
Review a sample report here
DFM Report
Your Fictiv Project Management Team
All injection molding orders have a team of dedicated Fictiv employees working tirelessly behind the scenes to ensure your parts are manufactured on time and to your precise specifications.
Account Executive
Your Account Executive will guide you through the quoting stage. They will help to gather your design requirements, request manufacturability feedback, and align your budget & timeline needs with Fictiv's manufacturing capabilities.
Technical Applications Engineer
Our technical applications engineers are trained manufacturing experts that provide manufacturability feedback on your designs during the quoting stage.
Customer Success Manager
Once your order kicks off, your Customer Success Manager is in charge of managing any of your questions or requests along the way.
Technical Project Manager
The Technical Project Manager is in charge of managing communications with Fictiv Manufacturing Partners to ensure your exact design and project specifications are communicated accurately. They will work tirelessly behind the scenes to ensure you receive quality parts, on time.
supplier quality engineer
To ensure part quality, Fictiv's Supplier Quality Engineers will conduct quality assessment of your parts at the factory and will also be in charge of organizing the First Article Inspection report as well as any other quality inspection reports requested.
CNC Plastics
ABS
This material is a low-cost engineering plastic widely used for pre-injection molding prototypes. Easy to machine, glue, and paint.
Max Temperature
160° F
Elongation at Break
40%
FINISH AND APPEARANCE
Somewhat matte finish (think lego bricks) and can be painted. Certain faces may appear more shiny depending on their geometry and how they’re machined
COLORS
Natural, Black
Min Wall thickness
1.0 mm
Polycarbonate CNC machining material CNC machined polycarbonate
Nylon
Well-rounded and affordable, this is a common grade of nylon that resists both frictional and chemical wear.  It is moisture-sensitive, however.
Max Temperature
185° F
Elongation at Break
50%
Milky-white finish, and is slightly translucent.
COLORS
Natural
Min Wall thickness
1.0 mm
Acrylic
Scratch-resistant, often used for tanks, panels, and optical applications. It can be somewhat brittle in thin walled areas, so it is not recommended for delicate or complex geometries.
Max Temperature
170° F
Elongation at break
6%
Transparent or opaque in its unfinished state. Clear acrylic will take on more of a frosted translucent appearance when machined, though can be smoothed again to an optically clear state using various finishing methods.
COLORS
Optically clear
Min Wall Thickness
1.0 mm
Delrin CNC machining material CNC machined delrin
Delrin
Wear and moisture resistant, slippery, and quite dimensionally stable for its cost. May also be called acetal homopolymer.
Max Temperature
180° F
Elongation at break
25%
Delrin is naturally opaque white because of its crystalline structure and has a matte finish.
COLORS
White, Black
min wall thickness
1.0 mm
HDPE
Slippery plastic that is often machined into plugs and seals. It is also an excellent electrical insulator as well as being moisture and chemically-resistant.
Max Temperature
180° F
Elongation at break
500%
Naturally opaque white because of its crystalline structure, but is also available dyed black in more limited stock sizes. It has a waxy finish leveraged for low-friction applications.
COLORS
White
min wall thickness
1.0 mm
POLYCARBONATE
Well suited for applications requiring optical clarity, yet is only half the weight of glass. Also known for its functionality over a wide temperature range.
max temperature
180° F
elongation at break
110%
Transparent milky-blue look in its natural state, also available in black. Both colors have a glossy finish, and are relatively prone to scratches. Anti-scratch coatings and vapor polishing are available as custom post-processing finishes.
COLORS
Clear, Black
min wall thickness
1.0 mm
Max part size: 1220mm x 500mm x 150mm
CNC Metals
Stainless steel CNC machining material CNC machined stainless steel
Steel - 1018 low carbon
Mild, low carbon steel that is machinable, weldable and useful where high-strength is not required, such as fixtures and mounting plates. It is magnetic and heat treatable.
Hardness
Rockwell B90
tensile strength
60,000 psi
The finish of 1018 steel is similar to that of stainless steel, generally shiny in appearance and  slightly dark than aluminum alloys.
COLORS
Silver
Min wall thickness
0.5 mm
Aluminium
A relatively cheap and widely available metal that is known for good machinability, corrosion resistance, and its conductive properties.
Hardness
6061: Brinell 95
7075: Brinell 150
elongation at break
6061: 12.50%
7075: 11%
Untreated aluminum generally has a dull silver/grey finish which varies depending on the roughness of the surface.
COLORS
Silver
min wall thickness
0.5 mm
Brass (360)
Also known as free machining brass, due to it having the highest amount of lead content of any brass alloy. It is commonly used for a variety of parts such as gears, lock components, pipe fittings, and ornamental applications.
Hardness
Rockwell B35
tensile strength
15,000 psi
Shiny yellow finish that varies depending on surface roughness. It can be sanded or hand-polished to increase its sheen (think trumpet or saxophone), or media blasted for more of a matte texture.
COLORS
Gold/brass
Min wall thickness
0.5 mm
Stainless Steel
A workhorse of a material, used for a wide variety of applications and known for excellent strength and corrosion resistance.
hardness
303/316L: Rockwell B95
304L: Rockwell B80 (medium)
17 PH: Rockwell C35
tensile strength
303: 35,000 psi
304L/316L: 30,000 psi
17 PH: 160,000 psi
Greatly depending on surface roughness, but it’s generally characterized as being more shiny than unfinished aluminum alloys, and slightly darker and more silver in color.
COLORS
Silver
Min wall thickness
0.5 mm
LEAD TIME
Production + Delivery = Lead Time
Production Speed
CNC parts are fabricated with options of 3-day, 5-day, and 7-day production speeds.
Delivery Options
  1. Pick it up from our local San Francisco office
  2. Receive via same-day courier service
  3. Standard and overnight shipping outside of local coverage areas
MACHINES, TOOLING, FINISHING
Machines
The Fictiv network is comprised of high-precision mill and lathe machines. We’ve aggregated a diverse selection of machines to provide a wide range of machining capabilities for your part requirements. We regularly inspect machines and tools on-site to ensure quality. Below are some examples:
Milling machines
  • Haas VF-3SS
  • Mazak VCN 510C
  • Mazak Variaxis J-500 (5-axis)
  • More (ask us)
Turning machines
  • Haas ST30SSY
  • Takisawa EX-308 (live-tooling)
  • Hardinge T-42 SP-MSY (live-tooling)
  • More (ask us)
cnc milling machine
Tooling
With Fictiv, your parts can have more feature variety due to a wide selection of tools carried throughout our network. Below are some major categories:
Milling (standard tools)
  • Square/ball endmills
  • Drills (in. & metric)
  • Keyseat cutters (square profile)
  • Counterbores / countersinks
  • Chamfer cutters
  • Standard taps & dies (UNS/metric/NPT/NPS)
Turning (standard tools)
  • L/R-handed facing
  • L/R-handed turning
  • Grooving / parting
  • Boring
  • Threadcutting
CNC machining standard tools CNC tooling for milling and turning
Finishing
Need a special finish on your parts? Fictiv offers the following processes for machined metals:
Finishing options
cnc finishing services
We're here to help every step of the way.
Talk to a Fictiv Rep
“Since starting to work with Fictiv, we’re able to take on projects with more complex manufacturing requirements.” —Miguel Piedrahita, Founder, 219 Design
Read Case Study
Design Guides
Get smart on injection molding
A collection of industry best practices including; recommended wall thickness, boss design, and gate types.
Free Download
